rzr awd not working cage is new superatv alum
This is a discussion on rzr awd not working cage is new superatv alum within the Engine and Drivetrain forums, part of the Technical category; I bought the super atv alum sprague roller.It worked great for 2 day of riding and just quit . the awd light comes on the ...
Old November 22nd, 2009, 03:42 PM
svtgregory's Avatar
svtgregory
First Name: Jason
My RZR: 08
Member #10170
View svtgregory's Photo Gallery(0)
Angry rzr awd not working cage is new superatv alum
I bought the super atv alum sprague roller.It worked great for 2 day of riding and just quit . the awd light comes on the speedo. I took the front differincial out and no broke cage or gears. I also checked the ohms on the hub coil it had 22.6 ohms. I think that was a good reading not sure thought. please somebody help me out
Old November 22nd, 2009, 04:41 PM
MotoXXX's Avatar
Feedback Score: 24 reviews
First Name: Jeff
My RZR: 08 with 2010 "S" MCX turbo motor
Member #4542
Re: rzr awd not working cage is new superatv alum
That is a good reading. Should be 21.6 - 26.4 Ohms per the service manual.
You can download the manual here, although it is slow if you are not a rapidshare member....
We did have a sticky thread with a link to it on hthis site but its gone!
Old November 22nd, 2009, 04:46 PM
MotoXXX's Avatar
First Name: Jeff
Member #4542
It may be a warped armature plate, or the coil is not seated in the U groove properly. Check both of those items. A wear mark with an interrupted wear pattern, rather than two distinct wear patterns (one inside of the other) is a symptom of warpage of the plate.
Old November 22nd, 2009, 04:51 PM
bioaction2's Avatar
My RZR: AEROCHARGED RZR4 STROKER!
Member #2604
View bioaction2's Photo Gallery(0)
Did you replace the fluid or reuse the old? Was it the correct type front and rear are diff.
Old November 22nd, 2009, 06:42 PM
speedjunky's Avatar
First Name: Tom
Member #2409
View speedjunky's Photo Gallery(0)
Watch the Super ATV video, he says something about squeezing the springs a littleor the AWD wont work.
Old November 22nd, 2009, 07:03 PM
hbchad's Avatar
First Name: Hudson
My RZR: 08 800
Member #9966
View hbchad's Photo Gallery(6)
Yup I'd check the spring clips...
The super atv video where he talks about them is here POLARIS RZR SPRAGUE CARRIER / FRONT ROLLER CAGE #550
P.S. Yall can get the service manual on my site at Natural ATV...The Home of the Natty Boys :: Home
"You know you're going deep when you've got a scuba tank sitting shotgun..."
2008 RZR - Lots of stuff!
'99 335 4x4 Sportsman for sale $900
Ride with the Natty Boys www.naturalatv.com
Old November 24th, 2009, 03:41 PM
svtgregory's Avatar
svtgregory
First Name: Jason
My RZR: 08
Member #10170
the fluid was new 6.75 oz of the polaris hillard clutch fluid. I have the service manual but could not figure out the coil depth( u shaped groove they were talking about). I ran the rzr for approximatly 10 hr before the awd quit. the thrust plate looked good on the wear platern not skip in wear lines . thanks for everbodys help very much appreciated. jason svtgregory
Tags
awd not working, front difff, no fourwheel drive
2009 rzr awd fluid
99 sportsman 335 awd
99 sportsman 335 awd not working
armature plate for polaric 550 snomachine
awd
awd not working
awd not working on rzr
awd not working properly
cage springs
hilliard clutch cage replace
new cage and rollers armature plate and still no awd on my rzr
ohms on a polaris hilliard clutch
polaris rzr awd not working
polaris rzr awd problems
polaris rzr display not working
roller cage
rzr awd
rzr awd fluid
rzr awd not working
rzr awd quits
Alum. / Steel A-Arms sporlan General RZR Discussion 0 October 17th, 2009 04:28 PM
alum wheel lugs superman Want to Buy 5 August 23rd, 2009 08:28 AM
RZR A-Arm skids in Steel Or Alum. RZR HQ SXSHQ 6 March 7th, 2009 02:24 PM
RZR rear alum, a-arm/cv guards by EMP gunrunner Polaris RZR Parts For Sale 0 January 27th, 2009 01:20 PM
Looking for Alum Rim BobVerde Misc For Sale 0 January 10th, 2009 10:34 AM
