Automatic AWG (HELP)
This is a discussion on Automatic AWG (HELP) within the Engine and Drivetrain forums, part of the Technical category; Good afternoon to all. I have owned polaris for years. This is the first time purchasing a side x side though. It is a 2009 ...
Old November 15th, 2009, 11:19 AM
phillip9174's Avatar
Member #11314
View phillip9174's Photo Gallery(0)
Good afternoon to all. I have owned polaris for years. This is the first time purchasing a side x side though. It is a 2009 RZR-S. I will post picks here soon. Anyway to the point. I have only had it for 4 months. Last night I was trying to climb a very small but steep incline. The front wheels came up at the top and I let off. When they came down I hit the gas to climb on up and there was a loud pop and lost the front pull on the AWG. Every thing apears to be ok visually but it still will not ingage. Is this a problem that every one is having and what can I do to check it myself before I take it to the dealer?
Old November 15th, 2009, 11:47 AM
Gerry Roach's Avatar
My RZR: plan on buying rzr in spring 09
Member #4773
View Gerry Roach's Photo Gallery(0)
Re: Automatic AWG (HELP)
sounds like you blew the rollercage in your front diff. As many will tell you the OEM one is plastic and made to self destruct when the front hubs are engaged with the wheels spinning then stopping suddenly. I would take it back to your dealer on warrenty. If he gives you crap try another dealer. This is not a new problem and others might have better advice
Old November 15th, 2009, 12:04 PM
Tuf-Skin's Avatar
First Name: Clifford
My RZR: 2009 RZR-S + MCX Turbo Apex (RZR-X)
Member #2228
If you need a billet carrier, here is a video about installing them:
______________________________________
My Links:
Polaris Parts Microfiche , How to change a RZR clutch belt VIDEO
Free Downloads: 2009rzr800, 2009rzr170, 2010rzr800, 2011rzr800, 2011rzr900xp, 2012-2013rzr170, 2013rzr900xp-eps, Yamaha Apex
other rzr service manuals for sale here: brssm website (not affiliated with this forum)
Old November 15th, 2009, 12:19 PM
Member #11314
Thanks guys for the info. I plan on taking it for warranty repair. I failed to mention I added 15" 29 x 10.5 rims and super swamper tires to my unit. Should I remove them before going for service? Also, could that be the reason for the AWG going out? If you guys think that is the case I will remove them for good and go back to factory.
Old November 15th, 2009, 12:35 PM
bagman's Avatar
My RZR: Gen 1
Member #649
They may not give you warranty anyway calling it abuse.
If you leave those tires on you'll give them a bigger reason to void your warranty.
If you want to run those tires and continue to break the cage (assumption) you'll prolly need to go aftermarket aluminum as in the video.
Old November 15th, 2009, 01:53 PM
King of crash!
Member #787
yes thats alot of tire to turn...deff put stock back on.....
Old November 15th, 2009, 02:01 PM
bagman's Avatar
My RZR: Gen 1
Member #649
I still think it's amazing that the high horsepower machines (Webers, mine ) haven't torn up something in the drivetrain.
Maybe the sand doesn't have the bite dirt/mud has and is easier on them.
  #8
Old November 15th, 2009, 02:03 PM
King of crash!
Member #787
same here the guys from back east seem to break everything and the duners dont...well as often
  #9
Old November 15th, 2009, 03:00 PM
rogo159's Avatar
Feedback Score: 8 reviews
First Name: Roger
My RZR: 08 RZR
Member #8843
View rogo159's Photo Gallery(0)
I run 29.5x10x12 Outlaws and have never had a problem. It is all in how you drive it. It's not a tank, boat, plane, or submarine. When you do what you do, expect to have problems. I have used my RZR in all four catagories, and so far, not much problems. But when something does break, I know it is my fault.
Team Offroad Powersport #32
http://photobucket.com/rogo159
  #10
Old November 15th, 2009, 04:15 PM
Gerard's Avatar
Make It Happen!
First Name: Gerard
My RZR: 2008 RNP Intake, Fuel Controller and Exhaust
Member #5640
View Gerard's Photo Gallery(0)
I would get an aluminum cage and have them install it under warranty. Tell them you want to be reimbursed for the amount of the stock cage. This way you won't need to replace the crappy stock one when it breaks and the warranty is out.
  #11
Old November 15th, 2009, 04:40 PM
bagman's Avatar
My RZR: Gen 1
Member #649
I seriously doubt Polaris would do that under warranty. They used a plastic cage prolly to protect other drive line components and only time will tell if the aluminum cage will lead to other things breaking.
The mechanic would be taking a big risk by assuming he knew more than Polaris on a warranty repair. Plus the bill back to PoPo would need to show the correct part as part of their warranty claim they submit.
But he could try!
  #12
Old November 16th, 2009, 07:05 PM
Gerard's Avatar
Make It Happen!
First Name: Gerard
Member #5640
But he could try!
Yeah, it depends on who he is dealing with and how good he knows them. I modified my Yamaha YFZ450 the day I bought it and the dealer said they would cover any and all parts if something broke.
  #13
Old November 16th, 2009, 07:10 PM
Cajunrzr's Avatar
First Name: Hunter
My RZR: 2009 RZR-S
Member #5457
View Cajunrzr's Photo Gallery(0)
Hey philip, can u post pics of ur rig with the swampers on it?
  #14
Old November 17th, 2009, 08:41 PM
Member #11314
Here is a pic of my ride
  #15
Old November 17th, 2009, 11:18 PM
Cajunrzr's Avatar
First Name: Hunter
My RZR: 2009 RZR-S
Member #5457
Man, that looks bad!!!!! I hope u can solve the issue so u can keep running them!! And yeah, put the factory ones back on when u bring in for service.
2008 polaris rzr diff cage
How do I disable my automatic headlights? bodykits Lighting, Stereo and Electrical 18 May 17th, 2009 02:37 AM
