No 4WD in reverse - Polaris RZR Forum - RZR Forums.net
No 4WD in reverse
This is a discussion on No 4WD in reverse within the Engine and Drivetrain forums, part of the Technical category; Anyone have experience with intermitent activation of 4WD or AWD in reverse only? When I push the AWD button and go into reverse the AWD ...
Old September 24th, 2009, 09:13 AM   #1
kedi's Avatar
First Name: Ken
My RZR: Gen II 2008
Member #1014
View kedi's Photo Gallery(1)
Question No 4WD in reverse
Anyone have experience with intermitent activation of 4WD or AWD in reverse only? When I push the AWD button and go into reverse the AWD icon does not always come on nor does the "R". But I can still move in reverse but no front wheel engagement. It usually works when the machine is cold but after running a bit the engagement does not work. Everything works properly when going forward AWD or 2WD. ???
kedi is offline   Reply With Quote
Old September 24th, 2009, 09:20 AM   #2
bigmike58's Avatar
Member #1218
View bigmike58's Photo Gallery(0)
Re: No 4WD in reverse
Mine turned out to just be dirty fluid....drain it...rinse it. fill it.. i'll bet it works again...
bigmike58 is offline   Reply With Quote
Old September 24th, 2009, 09:51 AM   #3
Family Rzr
410fortune's Avatar
First Name: Jamie
My RZR: 2009 RZR S
Member #8045
View 410fortune's Photo Gallery(0)
I know my 2000 Polaris Sportsman 500 4x4 has a reverse override button on the handlebars, if you want to engage 4x4 in reverse you have to hold it in
I am pretty sure the yellow button on the rzr dash does the same thing, if you need 4x4 in reverse (front end) you have to hold the yellow button... Ill check the owners manual and find out, it makes sense though
1988 Bronco II, 5.0L Gt-40p, 4r70w, 35" MTZ, dual ARBs, long travel
2007 FJ cruiser, 3" OME, dual ARBs, 4.56, 33" MTR
2005 (2ea) 900 RMK, 159", modified
2009 Rzr S - way too stock
410fortune is offline   Reply With Quote
Old September 24th, 2009, 10:04 AM   #4
Feedback Score: 16 reviews
guy48065's Avatar
Member #309
... the AWD icon does not always come on nor does the "R".
Your Rzr isn't going into 4WD because there's no "R" on the speedo. The computer needs to see that it's in gear and that the rpms are above some point or no-workee. Find the resistor pack under the seat near where the ground wires are bolted to the frame. Unplug it and clean the contacts real well. Fill the pins with dielectric grease and reassemble. That usually cures the intermittant gear indication problem.
Less common is the switch itself located on the transmission. If cleaning the resistor pack doesn't cure the problem, do a search here for how to remove the selector switch & clean it.
HTH
guy48065 is offline   Reply With Quote
Old September 24th, 2009, 10:20 AM   #5
Feedback Score: 17 reviews
FJK's Avatar
First Name: Frank
Member #8689
View FJK's Photo Gallery(279)
He' right if the speedo does not see R then neither does the computer = no 4 wheel drive
FJK is online now   Reply With Quote
Old September 24th, 2009, 10:25 AM   #6
bigmike58's Avatar
Member #1218
I need to read closer...just saw intermittent...lol
Mark sounds like he's been there!!!lol
the fluid did fix mine but i had the dash indicators..
Old September 24th, 2009, 10:35 AM   #7
FJK's Avatar
First Name: Frank
Member #8689
the speedo acts as a head end for the computer ,if the speedo does not see the command the computer will not respond,I thought when i went riding i could get away from computers NOT any more.LOL
Old September 25th, 2009, 08:51 AM   #8
kedi's Avatar
First Name: Ken
My RZR: Gen II 2008
Member #1014
Well we cleaned up the resistor pack under the seat, no change, so next is the selector switch. thanks
Ken
Old May 2nd, 2010, 10:18 PM   #9
GIXXERGUY6's Avatar
First Name: Ron
Member #6010
View GIXXERGUY6's Photo Gallery(0)
Are you talking the selector switch on the transmission itself?
Where is this located? I have a manual to look at but if you can point me in the right direction I won't take my laptop to the rzr
screw it
is that what you are talking about removing and cleaning?
GIXXERGUY6 is offline   Reply With Quote
Old May 2nd, 2010, 10:46 PM   #10
King of crash!
Member #787
yes it is...... i had the same problem a wire had broken off in side the switch ....be carefull when you remove it... their are two spring loaded pins that like to pop out.... it fits tight and a pain to get at... their is a switch test in the manule its easy and will tell you if its bad..... i think its about 150 bux new
you only need to take the switch out not all the rest...
Old May 2nd, 2010, 11:25 PM   #11
GIXXERGUY6's Avatar
First Name: Ron
Member #6010
jonny,
thanks for the heads up but I'm not seeing where you test the above pictured switch in the manual..I see in section 10.14 about testing the
gear position indicator switch.
We removed the "black dead end plug" and cleaned it, applied di-electric grease and reinstalled and made sure it wasn't coming apart or loose again... even secured it so it doesn't flop around when the machine is bouncing. It worked fine(the reverse 4x4) for the next couple days and then my buddy went out to check it out and said it wasn't going into 4x4 in reverse again...
Old May 2nd, 2010, 11:56 PM   #12
kedi's Avatar
First Name: Ken
My RZR: Gen II 2008
Member #1014
Yep me too. Last time I went out, short little run to see if my head would hit the cage after my chop, and it worked. Before that it didn't. I plan to clean everything again to see what happens.
Ken
Old May 10th, 2010, 11:55 AM   #13
GIXXERGUY6's Avatar
First Name: Ron
Member #6010
Jonnycat do you know where to find the instructions for testing this sensor on the bottom of the transmission? We still can't get the 4wd to work in reverse.
thanks in advance
Old May 25th, 2010, 02:45 PM   #14
GIXXERGUY6's Avatar
First Name: Ron
Member #6010
Resistor pack near the battery was gummed up and not plugged in all the way. removed it, cleaned with electrical cleaner, applied dielectric grease. Also cleaned the plug that it plugs into with cleaner several times and blew out with air. It worked great after that(for that night) and then didn't work.
We changed the transmission fluid and it worked after that. Loaded it on the trailer, unloaded it at Bundy Hill and it worked. Got in a mud hole and got stuck and switched to 4x4 and it worked in F, but not in R(in the mud hole) got winched out and went on our way and 5 minutes later used the switch again and it worked for the rest of the day on and off F and R.... Went to use the machine again last weekend and it worked but then didn't work.
It doesn't like reading it sometimes from F to R but will from P to R or something like that.
Any help? We are going to Harlan in 2.5 weeks and would like to have 4x4 in Reverse is possible.
Sensor on trans or that resistor pack?
I need to know so we can order it or do what we have to do before we leave
Old January 15th, 2011, 03:05 PM   #15
DBLTRBL's Avatar
My RZR: 2008 RZR
Member #14924
View DBLTRBL's Photo Gallery(0)
just wondering did you ever check out this "yellow button" idea? does holding tghis give you AWD in Reverse? if so...do you hold the button while the AWD switch is ON?
let me know...THANKS!!
DBLTRBL is offline   Reply With Quote
1997 polaris xplorer 30p front wheels not engaging in reverse
2000 polaris sportsman 500 no 4wd in reverse bypass
2004 polaris sportsman 500 allwheel drive not working
2004 polaris sportsman 700 twin four wheel drive doesn't work in reverse
2005 polaris 330 magnum reverse override wont work
2005 polaris 330 magnum speedometer wont toggle from rpm
2006 polaris sportsman 4 wheel drive reverse does not engage
2008 polaris rzr 800 no 4x4 in reverse
how does 2004 polaris sportsman 700 four wheel drive work
how to engage 4wd reverse 2011 polaris 550 atv
polaris 550 atv no 4wd in reverse
spoortsman 4x4 wont engage when put in reverse
sportsman 500 4wd doesnt work in reverse
sportsman 700 over ride switch not working
sportsman 800 wont disengage wont work in reverse
reverse and neutral .only bigmike58 Engine and Drivetrain 3 April 28th, 2009 08:53 PM
AWD in Reverse kedi Engine and Drivetrain 13 March 3rd, 2009 06:14 PM
Intermittent AWD in Reverse... walbright Engine and Drivetrain 13 February 26th, 2009 08:47 PM
No reverse just grinds! CaptainKevin Engine and Drivetrain 2 January 17th, 2009 07:52 PM
Reverse Speed W_A_Watson_II Engine and Drivetrain 24 April 6th, 2008 10:08 AM
