Front end clicking noise?
This is a discussion on Front end clicking noise? within the Engine and Drivetrain forums, part of the Technical category; Went duning last night, was in 2 wheel drive most of the time. Noticed a clicking sound from front end, maybe left front? It makes ...
Old September 17th, 2009, 04:06 PM
Gerard's Avatar
Make It Happen!
First Name: Gerard
My RZR: 2008 RNP Intake, Fuel Controller and Exhaust
Member #5640
View Gerard's Photo Gallery(0)
Went duning last night, was in 2 wheel drive most of the time. Noticed a clicking sound from front end, maybe left front? It makes the noise with the wheels straight, and pushing it with engine off it makes the clicking sound?
Old September 17th, 2009, 04:21 PM
Big 'da' Awg's Avatar
Member #1946
View Big 'da' Awg's Photo Gallery(0)
Re: Front end clicking noise?
I ride mine in the Sierra Navada mtns and I have the same clicking especially in tight turning CLICK CLICK CLICK CLICK
Old September 17th, 2009, 04:29 PM
crazywatson's Avatar
Just kidding!
First Name: steve
My RZR: red
Member #3534
Jack it up and check to see if there is alot of play in the wheel.It might be a broken hub.Just a guess.It could also be a cv joint.
Old September 17th, 2009, 05:05 PM
layoutdude989's Avatar
Member #9647
View layoutdude989's Photo Gallery(0)
I have heard the same noise in mine and i have been told that it sould be the bearing carrier in the front differential. The stock one is made of plastic.
Old September 22nd, 2009, 06:35 PM
Gerard's Avatar
Make It Happen!
First Name: Gerard
Member #5640
I jacked up the front end today and spun the tires, couldn't hear the clicking sound from either side. I put it back on the ground and moved it and the clicking sound is gone. Maybe lifting it moved a cv joint position and that stopped the noise? I don't know, but atleast the noise is gone
Old September 22nd, 2009, 06:41 PM
Tuf-Skin's Avatar
Feedback Score: 5 reviews
First Name: Clifford
My RZR: 2009 RZR-S + MCX Turbo Apex (RZR-X)
Member #2228
View Tuf-Skin's Photo Gallery(6)
It can also be something simple like the castle nut needing to be tightened. Or the cone washers under the castle nut are sometimes installed backwards...
Another cause could be a bad or broken bearing...
______________________________________
My Links:
Polaris Parts Microfiche , FREE DOWNLOADS , How to change a RZR clutch belt VIDEO
Old September 23rd, 2009, 02:57 AM
powermizer's Avatar
My RZR: gen2
Member #458
View powermizer's Photo Gallery(0)
Yea I had 6 hrs and 180 miles and click click, bad inner cv joint, only showed in turns with load on it.
  #8
Old September 24th, 2009, 02:30 PM
Ronald Adams's Avatar
Member #330
View Ronald Adams's Photo Gallery(0)
Pull the hub off and put some never seize on the splines that will cure it most of the time
  #9
Old September 24th, 2009, 05:26 PM
scottw1171's Avatar
My RZR: 2009 Stealth Black
Member #8587
View scottw1171's Photo Gallery(2)
18 hours and 130 miles with that clicking, popping sound from front pass. side wheel..has a slight amount of play in it
at the dealer now for that issue and first service
  #10
Old October 1st, 2009, 07:08 PM
rich2009's Avatar
Member #10213
View rich2009's Photo Gallery(0)
ok i have had this noise on 3 of my rzr's there is an update for the front hub a simple spacer washer
7555939 polaris oem part number
my dealer replaced hubs and cvjoints noise was still there, anyhow, this tightens the hub and removes the play you get if you jack the front tire up and rock it in and out from the top of wheel.
  #11
Old October 1st, 2009, 08:06 PM
back from the sand & dirt
Feedback Score: 6 reviews
Member #787
also look for a worn lose lower ball joint bolt.....
lots of toy's
  #12
Old October 13th, 2009, 04:14 PM
Hooksman's Avatar
Member #10495
View Hooksman's Photo Gallery(0)
I am having the same issue on my 2008 with the 3" Xtreme lift kit. Notice more on the right side that the left. Started with the right side and pulled the wheel and spacers. The castle bolt was extremely loose on it. Service Manual says it should have 80lbs of torque. Broke off one of the wheel stud on the spacer so that just came in and going to test tonight. Hoping that was the issue.
One questions, I see about the coned like washers just inside the Castle bolt. Should there be 2 or 3. Looks like the wheel should have 3 cause the cotter pin is just inside the castle bolt. Anyone have any idea?
Update 10/15/09 -- Took apart all wheels and spacers. Noticed that on trhe front where the 2 coned washers are that the castle bolts were defintaley loose. Could use 1 more cone washer behond the castle bolt. Put all back together and tested and no more popping. Drove around and all seems well. Checked the rear also and they are much better than the front. Seems like this is another maintenance item to add to the checklist. Next item on the agenda is investigating for a long travel conversion.
  #13
Old October 23rd, 2009, 04:41 AM
Ned Fox's Avatar
Member #10718
View Ned Fox's Photo Gallery(0)
HI. I have the RZR at the Dealer and we'll see what they come up with and I will follow
up. thanks for your imput. Ned.
  #14
Old October 23rd, 2009, 06:35 AM
rogo159's Avatar
Feedback Score: 8 reviews
First Name: Roger
My RZR: 08 RZR
Member #8843
View rogo159's Photo Gallery(0)
Cone washers not being installed properly is a know problem. I would check the washers, and the torque on the castle nuts. All bolts with torque specs should be checked after break in period. All owners of a motorized vehicle should have a small collection of tools, and a multimeter...not to mention the service manual. Many of the repairs you can do yourself and learn more about your machine. A service manual is just cheap insurance.
Team Offroad Powersport #32
http://photobucket.com/rogo159
  #15
Old October 23rd, 2009, 01:14 PM
scottw1171's Avatar
Member #8587
well it turned out to be a loose brake caliper and hub nut..dealer added a dab of locktite..
clicking noise in front end of truck
2009 sierra clicking noise from front wheels
polaris rzr axle nut torque spec
what is clicking sound front wheel
polaris rzr service bulletin washer
polaris rzr front differential clicking
2008 polaris rzr front end clicking
rzr clicking up front
polaris popping noise when backing
popping or clicking in front wheels on polaris rzr
RZR clicking
hub washer
clicking noise fubar Engine and Drivetrain 16 May 6th, 2010 01:14 PM
2009 w/ clicking/snap noise snowdevil General RZR Discussion 11 March 22nd, 2010 03:28 PM
clicking in front end might be front diff Crispy01 Engine and Drivetrain 11 March 1st, 2010 07:05 AM
Clicking noise from right front pluscount Engine and Drivetrain 18 December 14th, 2009 09:35 PM
Rear end clicking noise cloud9 General RZR Discussion 6 February 28th, 2009 10:34 PM
Checkout the following websites in the UTV Forums Network:
UTV Blog - Yamaha Rhino Forum - Polaris RZR Forum - Kawasaki Teryx Forum - RedLine UTV Forum - Arctic Cat Prowler Forum - Honda Big Red Forum - Can-Am Commander Forum
