Does some one have the internal engine measurments for the RZRs? What I know is just the CR 11:1 and stroke 75.6mm
Rod Length
Deck Hight
Intake valve closing degree
chambers CCs in the head
Piston Dome CCs
Gasket Thickness
Deck high Clearance
Piston Ring Depth
Piston Top outside Diameter
Compression Hight
Rod Length
Deck Hight
Piston Dome CCs
Gasket Thickness
Deck high Clearance
Piston Ring Depth
Compression Hight
