getting rid of clutch spacer for more MPH?
Old August 9th, 2007, 01:13 PM
norcalsvx norcalsvx is offline
anyone know how to do this, thanks chris
2008 RZR
drangonfire G3 fuel
Uni filter
Re: getting rid of clutch spacer for more MPH?
Old August 9th, 2007, 09:10 PM
UTVPowersports UTVPowersports is offline
I pirated this from hunterworks, here you go!!
First let me say I don't recommend this at all because you can damage your primary sheave shaft if you are not careful but here goes.
Take the cover off the CVT and look into the primary sheave and find the plastic spacer. Take a chisel and cut the plastic spacer with it and a hammer then rotate it over and either pull it off or cut it again.
After riding some more my RZR runs 65mph now.
Old August 10th, 2007, 09:27 AM
cool thanks i'll see how i like it with the mods i am putting on
Old August 26th, 2007, 07:45 AM
jdhoggg's Avatar
jdhoggg jdhoggg is offline
UTV let me know if that mod causes any problems within the next few months as I want to do it to mine but can't afford to tear anything up right now......
Old August 26th, 2007, 01:29 PM
UTV CRAP's Avatar
UTV CRAP UTV CRAP is offline
Offical Site Sponsor
First Name: Nick
My RZR: #666 Race RZR - Soon
PDM (pdmaz.com) in Phoenix, Arizona offers this service for $189.95 I think (NOT 100% sure, just rumor I heard), he does it a little more complex and more careful from what I read above I'd assume as he is one of the most reputable clutch guys in Arizona !! Give him a call
Old August 27th, 2007, 07:42 AM
guy48065's Avatar
guy48065 guy48065 is offline
I've heard the chisel method works well, takes only a few minutes (all of 'em spent removing/replacing the cover), but if you're too aggressive you can nick the shaft. I don't know what type plastic the spacer is made from but I'd try melting thru it with a hot blade before resorting to whacking it. No reason to pay someone to do such a simple mod.
Now a 2-Rzr household.
http://tinyurl.com/8ltm8
Old August 27th, 2007, 10:08 AM
UTV CRAP's Avatar
First Name: Nick
warranty... if something goes wrong you have someone to turn to. and i think he is actually replacing the spacer with a new one.. but if you want to do it yourself, more power to you, just no recourse if you blow your clutch up, or do any other damages to your car.
Old August 28th, 2007, 07:13 PM
jdhoggg's Avatar
I was going to use a hot blade or a flat soldering iron I have to make sure I don't damage the shaft but I don't want to screw anything up. I just got my manual so I'm ready to do all this stuff now.
Old August 29th, 2007, 07:22 PM
Dirt Dobber's Avatar
Dirt Dobber Dirt Dobber is offline
First Name: Jeff
I didn't risk it. I took mine down to my dealer and he and i took it apart and removed the spacer. It takes a special tool to take the clutch apart. This mod works great for top speed increase, won't help the bottomend just the topend. This is a simple way to pick up a quick 8-10 mph. Warranty still good.
  #10 (permalink)
Old August 30th, 2007, 09:18 AM
jdhoggg's Avatar
Dobber,
How much did the dealer charge you?
  #11 (permalink)
Old September 2nd, 2007, 11:42 AM
martinbuilt martinbuilt is offline
Guys guys guys,
Please do not use a chisel, one wrong move and you could do alot of damage to that clutch shaft. After you remove the cover, then remove the 7 bolts around the clutch( this is NOT under any presure from the spring) then remove that outer part of the clutch, reach in , grab the spacer and remove it, now retorque the 7 bolts, done. No need to remove the clutch and no fancy tool needed. You will gain 5 mph.
Martin
  #12 (permalink)
Old September 2nd, 2007, 01:37 PM
UTV CRAP's Avatar
First Name: Nick
RZR Crap will be offering a couple of different clutch packages in the next few weeks here. We are going to Glamis to test different springs and setups to find the best duner kit for the RZR!
  #13 (permalink)
Old September 3rd, 2007, 01:24 AM
L86fae's Avatar
L86fae L86fae is offline
First Name: JB
My RZR: 2008 Red RZR
Let us know when you have a good dune setup. I will be heading to glamis most of the winter.
  #14 (permalink)
Old September 3rd, 2007, 09:18 PM
ford4442003 ford4442003 is offline
First Name: Greg
My RZR: First Edition
Question Re: getting rid of clutch spacer for more MPH?
Hello, I have had my RZR for about a month and removed the spacer for a short period but put it back in after about 50 miles because the belt exploded. I think that removing the spacer caused this because if you remve the spacer put the RZR in neutral and rev it up before putting the cover back you will see that the belt rides most of the way out of the clutch sheaves. It will run up to around 68 MPH if you look at your speedometer at the 70 MPH mark there is a red mark and it will run rite up to the red mark. JUST MY 2 Cents. I have 600 miles on mine now with no other problems but the spacer was removed at around 110 miles and the belt exploded at 168 miles.
  #15 (permalink)
Old September 4th, 2007, 03:41 PM
First Name: Jeff
Originally Posted by martinbuilt View Post
Guys guys guys,
Martin
He is right, I posted that you would need a special tool, but to do this mod its not needed I had a brain fart there for a min. My point is take the time to take it apart and do it the right way. You will need to torque the bolts back though. This is very simple and only takes about 1/2 hour to 45 min.
to answer the other question my dealer didn't charge me he's a good friend and we do stuff like this all the time.
