Horrible Rear End Noise
Old March 4th, 2008, 02:26 PM
cisco kid cisco kid is offline
After going fast about 50 to 55 and coming to a slow down speed, I get this horrible knocking noise, like steel parts locking into each other, like if you had a sandard tranfer case and you gear whent into a lower one. Don't know if it's the tranfer case, trany, rear diff, rear ball joints or ?????????
It was not in 4WD
It did this 3 to 4 times
After it was done with this noise all works fine
Did check all oils before the ride
I will check all in back end this weekend
Jest needed to know if anyone has had this horrible noise
Thousand Palms , CA
RZR #23
07 700XP
08 800RZR
Re: Horrible Rear End Noise
Old March 4th, 2008, 07:39 PM
Drymountain Drymountain is offline
If you have horrible rear end noise you need to quit eating beans and take some gas x.
Old March 4th, 2008, 07:47 PM
mtnmike's Avatar
mtnmike mtnmike is offline
kinda like a clacking from the rear when your hard on the brakes in chattery type terain?
Old March 4th, 2008, 07:56 PM
1idrod's Avatar
1idrod 1idrod is offline
My RZR: Gen 2 Green
I posted this exact same thing somewhere, but took it to dealer and they checked it out and the only thing they found was some water in rear diff even though the only water I've been in is washing it and crossing streams, nothing extreme. They said only thing found other than that was bearing was scourd? Picked it up 2 days ago and haven't heard the sound yet. I don't know if thats the whole story or not, it only took them 1 1/2 weeks to figure that out and I was not smart enough to get a report in writing before I left because I wanted to ride.
Old March 5th, 2008, 10:22 AM
If anyone has anyother ideas to look for jest post and I will add to my list ;-)
So far I got:
1. Re-check all oils
2. The bearings
3. Broken Brake Pad
4. Loose calliper
5. Slack in the diff
6. Rock caught in brake disk hole hitting caliper
7. Dirt stuck to brake disk
8. Small rock caught in motor mount
9. Cracked or brken sway bar
Old March 5th, 2008, 10:23 AM
Hey it's free GAS ;-)
Old March 5th, 2008, 10:26 AM
No noise when pressing brakes ;-)
Old March 5th, 2008, 10:27 AM
So far I got:
2. The bearings
3. Broken Brake Pad
4. Loose calliper
Anymore ????????
Old March 5th, 2008, 11:05 AM
mtnmike's Avatar
you didnt respond to my question about the clack if it sounds like a clack i think it might be slack in the diff.i recomend getting all 4 tires in the air(up on jack stands) and twist one of your rear wheels rapidly in a foward and reverse motion and see if this is the noise you hear just a thought mtnmike
  #10 (permalink)
Old March 5th, 2008, 11:26 AM
Sorry, I will try to do this this weekend and if we get a slack in diff any thing that we can do ;-)
  #11 (permalink)
Old March 5th, 2008, 12:53 PM
mtnmike's Avatar
i have not been in the rear diff yet so im not sure whats goin on in there,but i have the clack as i described and my rzr is in the air when i jerk one of the rears back and forth it sounds damn near identical to what i hear while driving
  #12 (permalink)
Old March 5th, 2008, 01:01 PM
mtnmike's Avatar
after going out and doing it agin not shure if its the diff or tranny on mine,but nothin has broke yet so?
  #13 (permalink)
Old March 5th, 2008, 01:50 PM
Thanks for your input, it will help ;-)
