Dynatek adjustments
This is a discussion on Dynatek adjustments within the Engine and Drivetrain forums, part of the Technical category; I recently installed a Dynatek Programmable CDI (DFS9-3), Coil (DCK9-2), and Serial Programmer (DRSP-1). This is my first time to add these to a bike, ...
Old July 2nd, 2009, 06:49 AM
Joe9216's Avatar
First Name: Joe
My RZR: '09 RZR 800 Red
Member #7394
View Joe9216's Photo Gallery(0) Send a message via Yahoo to Joe9216
Dynatek adjustments
I recently installed a Dynatek Programmable CDI (DFS9-3), Coil (DCK9-2), and Serial Programmer (DRSP-1). This is my first time to add these to a bike, and I have no idea what im doing when tuning. No shops around me have a dyno willing to run my bike. I heard to use a wide band o2 sensor, but I dont know how to use one or adjust the cdi with it. Any help with this will be much appreciated.
Old July 2nd, 2009, 07:22 AM
Cordachine's Avatar
Look'n 4 da deep stuff!
First Name: Don
My RZR: 08 Red Submarine
Member #2636
View Cordachine's Photo Gallery(0)
Re: Dynatek adjustments
When you get the wide band O2 sensor and gauge, you will be able to tune your air/fuel ratio at low mid and high. This will allow you to optimize how your engine is running. Do some searching and see what A/F ratio guy are running at.
08 Popo RZR and 02 Sportsman X 500 HO (mudder) (dead)
RZR mods: 30" Mudzillas on 14" SS108, 3000lb Winch, K&N Apollo, 3" Xtreme Lift Kit, HL springs, Custom snorkle, Deluxe front and rear bumpers, Rock slider nerf bars, Sport roof, FMF pipe, 1 1/2" Wheel spacers, 4 pt harness, rear view mirror, RZRFORUMS.NET flag, Dynatek CDI, Dynatek Controller
Old July 2nd, 2009, 04:16 PM
PM720's Avatar
Member #7819
View PM720's Photo Gallery(0)
It would probably help everyone to know what your other mods are to help them make suggestions. Any intake or exhaust mods? Internal engine mods? Turbo? Nitrous?
Old July 3rd, 2009, 06:08 AM
stroker0836's Avatar
First Name: tom
My RZR: the green one
Member #2742
View stroker0836's Photo Gallery(0)
you need to use a wideband o2, it doesn't make any diff. what mods you have or don't have, a/f settings are what makes these things run. 14.7 is the industrie accepted standard for optimal milage . if you get yours set between 13.2 and around 14.5 under all conditions, you will be close. you have to leave the programmer plugged in or you will lose the dialed in adjustments, never mind what the instruction sheets say. THEY DON"T REMEMBER THE SETTINGS WHEN PROGRAMMER IS REMOVED. stroker
Old July 3rd, 2009, 09:56 AM
PM720's Avatar
Member #7819
Hey, I was just thinking if someone had similar mods they could share their settings to at least get him close. I agree that tuning yourself with a wideband is the right way to go. Not everyone can deal with this though.
Why do you say they don't remember the settings?
Old July 5th, 2009, 12:29 AM
Joe9216's Avatar
First Name: Joe
Member #7394
I have a mud industries snorkel, stock airbox with k&n filter, HMF XL swamp series single exhaust, EPI Sport utility clutch so far.
Bookmarks
Rear suspension adjustments Joey RZR-S Specific Discussion 2 May 13th, 2009 07:15 PM
any fuel adjustments for exhaust? psycholime Engine and Drivetrain 5 May 5th, 2009 12:55 PM
Factory shock adjustments... BlueSTI Suspension 18 March 17th, 2009 07:55 AM
Fuel adjustments RZRDavis Engine and Drivetrain 1 February 8th, 2009 10:38 PM
Fox Suspension Adjustments for various terrains CalifRZR-S RZR-S Specific Discussion 28 November 25th, 2008 02:29 PM
