Which wideband A/F?
Old February 26th, 2008, 05:56 PM
gimpygolden gimpygolden is offline
Which wideband A/F?
What is everyone using for a wide band air/fuel ratio.
I see dynojet makes a nice one the WideBand Commander
Wide Band Commander - Product Information,but is something that hi tech really needed to tune for an intake and exhaust or can I get by with something like this Summit SUM-G2995 - Summit Wideband Air/Fuel Ratio Gauges - summitracing.com
at less than half the cost?
What are your thoughts?
Re: Which wideband A/F?
Old February 26th, 2008, 07:59 PM
BIG ISLAND KART SHOP's Avatar
First Name: JASON
I Use The Wideband Commander, It Works Great! Hpd Recomended It To Me. IT HAS MORE FEATURES THAT YOU DON'T REALLY NEED LIKE NOS, BUT IT ALSO DATA RECORDS AND THEN YOU CAN UPLOAD TO YOUR PC. I DON'T USE ANY OF THAT EXTRA STUFF BUT STILL REALY LIKE UNIT.
Old February 26th, 2008, 08:02 PM
martymoe's Avatar
martymoe martymoe is offline
Mad Scientist
First Name: Marty
i have the wbc too and have it linked to my powercommander, it's awesome for tuning.
Old February 26th, 2008, 08:46 PM
quadnkev's Avatar
quadnkev quadnkev is offline
First Name: Kev
My RZR: Red for now!
Are you using the HPD RZR pipe?
I have one one order and am getting the Power Commander 3 for it and am wondering if they have a download map for stock, and for an intake and PRC pipe to download yet. After a while I will step up to the A/F stuff but will need a bit of breathing room after the first round of add-ons.
Old February 26th, 2008, 09:05 PM
h&knut h&knut is offline
same here wbc
Old February 26th, 2008, 09:17 PM
First Name: JASON
I THOUGHT THE FUEL CONTROLLERS WERE NICE (DRAGONG FIRE, BOONDOCKER ETC.) YOU CAN ADJUST THEM IN THE CAB WHILE YOUR DRIVING. I HAD A POWER COMMANDER ON MY CBR 1000RRR AND I HAD TO HOOK IT UP TO PC TO ADJUST. IF YOUR GOING TO USE POWER COMMANDER AS FUEL CONTROLLER MAKE SURE YOU CAN PUSH BUTTONS TO ADJUST IN CAB, I HAVE NOT SEEN ONE ON AN RZR YET, SO I DON'T WHAT IT CAN DO.
I HAVE GRAGON FIRE PIPE AND FUEL CONTROLLER, HPD PIPE WAS NOT OUT YET. ANY ONE WANT TO BUY A DRAGON FIRE PIPE?...
Old February 27th, 2008, 06:45 AM
martymoe's Avatar
Mad Scientist
First Name: Marty
the dynojet has buttons, but after you get your map set you will probably never use them.
i have the lcd module too and you can use that to adjust fuel settings (like you can with the buttons) the problem with the buttons is the mixture is only set in 2 dimensions. if you build good maps for your rzr, those maps are in 3d(rpm/tp/afr). if their built with a wbc, you shouldnt have to change them at all. you'll simply have a cruising map and a hotrod map and the only reason to switch is for a long trip and you wanna save gas.
Old February 27th, 2008, 03:14 PM
FASTDMAX's Avatar
FASTDMAX FASTDMAX is offline
First Name: JOHN
Hey Martymoe Which Power Commander Are U Running The Race Or The Street Version Thanks
Old February 27th, 2008, 03:15 PM
martymoe's Avatar
Mad Scientist
First Name: Marty
there is only one for the rzr. my guess is it's the race version
  #10 (permalink)
Old February 27th, 2008, 05:51 PM
FASTDMAX's Avatar
First Name: JOHN
i am getting ready to buy both the wbc and the power commander, other than what they come with, do you need anything else to link them together to tuning. thanks
  #11 (permalink)
Old February 27th, 2008, 06:01 PM
martymoe's Avatar
Mad Scientist
First Name: Marty
to link them youl need the lcd module and the link cable
  #12 (permalink)
Old February 27th, 2008, 06:20 PM
FASTDMAX's Avatar
First Name: JOHN
ok thank you
