Air box upgrade
Old February 25th, 2008, 10:46 PM
BigDog_Arizona's Avatar
BigDog_Arizona BigDog_Arizona is offline
First Name: Ray
My RZR: RZR 800
AZ Air box upgrade
The guys over at KMS performance put there new air box mod on my RZR.
I got to say I didn’t think it would make a difference…I was surprised. I would recommend this to others. It uses the stock air box so you can still run in water but they change the filter and intake.
“Speed cost money son how fast were you planning on going”
Sponsors:
KMS performance
Full throttle junkies.com
BS Sand Seats
Re: Air box upgrade
Old February 25th, 2008, 11:38 PM
BigAir's Avatar
BigAir BigAir is offline
Re: Air box upgrade
Any pics? There web site doesnt seem to have anything...Im still not sure what to do with mine
Re: Air box upgrade
Old February 26th, 2008, 12:39 AM
BIG ISLAND KART SHOP's Avatar
First Name: JASON
Re: Air box upgrade
Big Dog, Hook Us Up With The Info, I Am Also Interested... I Get Wet Some Times, Don't Really Want That Desert Can Filter.
Thanks.
Re: Air box upgrade
Old February 26th, 2008, 10:55 AM
KYRZR KYRZR is offline
First Name: Jimbo
Re: Air box upgrade
Summer is almost here & the dust will be boiling, I couldn't wait any longer to get my RZR ready. Since I don't plan on using it for a submarine, I skipped the snorkel fix & went with the "Grumpy" fix. Sealed up the air intake with black foam spray, added a few pieces of weatherstrip, cut a hole between the seats & added a pre filter with a speaker cover over it, works great. Went on my first ride last weekend & I'd bout swear it had a little more power than before. Sorry, no pics at this time.
Re: Air box upgrade
Old February 26th, 2008, 02:40 PM
Adam12 Adam12 is offline
Re: Air box upgrade
I dont even see web how about link...
Fly Low Avoid The radar
Re: Air box upgrade
Old February 26th, 2008, 06:48 PM
First Name: Jimbo
Re: Air box upgrade
I did a variation of this: PRC Forum - My intake Mod / Intake filter / UPDATE
Re: Air box upgrade
Old February 26th, 2008, 10:42 PM
First Name: Ray
My RZR: RZR 800
Re: Air box upgrade
Ok I think some of you may have misunderstood me. when I said “with the KMS air box you could go in the water”, I didn’t mean you could go swamping. I met you could do your normal riding in the mud and snow just like the stock air box. Without having a exposed air cleaner.
Re: Air box upgrade
Old March 5th, 2008, 10:09 PM
shenegar's Avatar
shenegar shenegar is offline
First Name: steve
My RZR: 08 red rzr
Re: Air box upgrade
pics and details.....i talked to them and they said a month before production
hc pistons,port work,valves, springs,guides,clutch kit,bored throttle body, pushrods,cam,and oil cooler from hpd,maier hood,black t-7 w/red beadlocks,maxxis 4-speeds,mb cage,LTE SINGLE, dragonfire airbox,lonestar brace and gussets,utvcrap tubes,pro ALUM bumper,emp skid,crow 4point. pcIII ,hotride ecu,custom gusseting,shawz panels and +4 with fox shocks,billet handle, cupholders, speedo, rails, cap,shifter ,polaris suspension seats, piaa lights
Re: Air box upgrade
Old March 8th, 2008, 08:54 PM
Grumpy Rider's Avatar
Grumpy Rider Grumpy Rider is offline
Grumpy Rider
Re: Air box upgrade
Originally Posted by KYRZR View Post
I'll swear by this fix....works great for me
Re: Air box upgrade
  #10 (permalink)
Old March 23rd, 2008, 10:19 AM
mdevans's Avatar
mdevans mdevans is offline
Re: Air box upgrade
pics of my air box after dealer did recall. all thay did was put some black foam on the frame at the bottom of the box and caulk the inlet for air filter housing. thay dident even clean the air box. I dident want to spend alot of money due to april trip so this is what i did. I had a outerwares cover for a air filter so i cut it and coverd the hole in the air box and i also had a filter so i modified it to cover the clutch outlet. this should get me by for now.
