Help Please |
February 25th, 2008, 10:38 PM
Help Please
I have a 2008 rzr and it runs like crap its only 3 months old . It has no midrange power . it has no trouble codes either. IM very enchanical as far as i can tell its running extremely lean !!! within the first 30 sec. of running the exhaust temp is already 900 degress at the manafold.
will a sportsman 800 ecu be better?
Re: Help Please |
February 25th, 2008, 11:02 PM
My RZR: 2008 Murdered Out RZR
Re: Help Please
Take it too your dealer before you void that waranty...
2006 Silverado 2500HD Custom Truck
2007 Weekend Warrior FSW3200
2008 Ranger RZR 800 EFI (w/kids rear bench seat!)
2001 ETON 50 ATV (Taylor's Old Ride!)
Coming Soon (Something for KatieBugs!)
Re: Help Please |
February 26th, 2008, 05:36 AM
Re: Help Please
jeromy ya what he said. take it to thy dealer. also while your there ask them the rpm range on an 800 sportsman cdi box.
Re: Help Please |
February 26th, 2008, 07:39 AM
Mad Scientist
First Name: Marty
Re: Help Please
sportsman ecu is pretty much the same..
you can take it to the dealer and let them look at it, but more satisfaction will come from fixing it yourself..
check the injector wires, make sure their both plugged in and in the right order..
if that's ok, put a meter on your tps signal wires..
make sure it reads about .739 at idle. if it doesnt, do a tps initialization.
also check the sweep, if the tps is bad that will mess you up too. wot should be in the 3.75 - 3.8v range
tps can cause all kinds of wierd problems, that voltage is what sets your ignition timing and fueling.
if it still doesnt run right, check fuel pressure at the schrader valve (37psi) you dont need a fancy fuel pressure tester. you can use a tire gauge just dont let it squirt gas in your eye.
Reason: i cant spell
Re: Help Please |
February 26th, 2008, 09:39 AM
Re: Help Please
How do I do a tps initialization??
2008 rzr snorkel, lift, 28x12x14 wheel spacers
Re: Help Please |
February 26th, 2008, 09:45 AM
Mad Scientist
First Name: Marty
Re: Help Please
there is a procedure in the service manual look under fuel injection it tells how to do it. you dont need the tps test harness just use the 5v vref from the ecu.
Re: Help Please |
February 26th, 2008, 10:22 AM
Re: Help Please
I dont have a service manual yet is there any way you can talk me through i t
Re: Help Please |
February 26th, 2008, 10:40 AM
Mad Scientist
First Name: Marty
Re: Help Please
Re: Help Please |
February 26th, 2008, 10:50 AM
Re: Help Please
thanks man
Re: Help Please |
February 26th, 2008, 10:56 AM
Mad Scientist
First Name: Marty
Re: Help Please
email if you have questions..
martymoe@martymoe.info
Re: Help Please |
March 3rd, 2008, 08:32 AM
Re: Help Please
I have a similar problem but will start a new thread.Please let me know your thoughts
Re: Help Please |
March 3rd, 2008, 03:04 PM
Re: Help Please
Jeromy,check your oil level.Mines 3 months old also and I"m burning oil from the rear cyl for some reason
