April 15th, 2008, 07:27 AM
First Name: tyler
My RZR: 08 green
Re: Front 4x4 problem
mine works when it wants to lately. the AWD switch light and dash icon don't light up at times, and other times it will. needed it to get through some stuff the other day and it wasn't working. i left it on and eventually it came on and worked fine the rest of the day. wiring problem?
08 rzr with 28" MST's on black ITP SS108s, polaris winch, pre runner bumper, 4 points, snorkel, custom laser cut grill, under dash dome light, horn, old school police light up top, soon to be aftermarket cage, more to come...
07 tundra crewmax 5.7 mostly stock
07 honda crf80 with 115 big bore and a whole lot more
06 honda crf450x street plated supermotard
00 honda cr250 hare scramble/dune bike
92 mazda b2200 show truck: flat black, bags, suicide doors, etc
April 15th, 2008, 08:44 AM
What broke on your front end. Do you have any mods?
May 4th, 2008, 09:21 PM
i just bought a new razor, brought it home, tried it in the yard yesterday and the front diff wouldn't engage or light up the icon on the dash if you disconnect the plugin for the font diff and check the grey wire with the key on engine off and the shifter in either reverse low or high you should have 12 volts at this grey wire if you don't your problem is probably like mine being the awd switch is faulty unplug the switch pull apart and the metal tab inside wasn't bent enough rearced it and put the switch back together and it now works fine everytime except when i took it out today , splashed through a puddle and got the front plugin wet it quit working momentarily unplugged and blew it out fine again i am going to install a water proof plugin tomorrow
May 5th, 2008, 11:30 AM
I really wish I wouldve just checked out if there was power going through the wire. I figured... hey its under warranty let them deal with it. What a mistake. So far in the last month they tore the front diff apart and worked with polaris making sure everything was within specs. I guess it all is so NOW they are thinking it might be electrical. Why the hell wouldnt you check that first? haha. Theyre killing me. Just goes to prove you cant trust too many people with your toys. At this point I wouldnt want them to change my oil.
August 31st, 2008, 03:44 PM
apparently im having the same problem,i told the dealer about 3 months ago about front wheels not turning while in allwheel dr , they said they tested it and it was fine. my unit has been in and out of the shop for MANY problems so i have not been able to ride much, finnaly today i put rear wheels up on a rolling floor jack and engaged awd, and what do you know, its not working. i have had this unit for 6 and a half months, and its spent about 3 and a half months in the shop. i thought maybe i was the only one that bought a lemon but apparently not. sounds like A LOT of us are having problems.
October 1st, 2008, 09:53 PM
I only have problems with my 4x4 in reverse. sometimes my reverse indicator on the dash doesnt come on, thats when the 4x4 isnt working. its fine in high and low. If the "R" is lit up on the dash then I have 4x4. what should I check?
October 1st, 2008, 10:23 PM
That sounds like something electrical for sure. My AWD works so far since I have had it back from the dealer. The problem I was told was some sort of "sensor bracket" being positioned wrong. All I know is that mine is under warranty for 3 years so if it didnt get fixed they will be seeing me again. I too ride in the dunes mostly. Alot of people who are just trail riding would never realize it or atleast not as much as pulling up a dune.
October 1st, 2008, 11:27 PM
First Name: Pierre(Pete)
My RZR: GEn 1
Your "resistor module" is going to die soon  That's why your "R" only lit some time. In a few ride, it won't lit at all and you can't have 4x4 without the "R" lit.
TEST IT: It his on the driver side of the battery, under your seat. Locate the main electrical harness and you'll see it. It come from the harness and is attached to it by a tyrap. Cut the tyrap loose then you'll be able to get the module off the plug(It's locked to the plug by the sides). Take ohm meter and test the resistance on the module (page 10-13 in shop manual) You won't have any resistance on the "R" position
Don't search the part number, you won't find it, your dealer will have to call the tech but i should have it tomorrow or friday. It cost 23$ C.
On mine, it was the "N" ;o)
October 3rd, 2008, 12:59 PM
these machines are pitifull.ive had mine for 8 months now and have had to replace.....top end in motor, front wheel bearings{twice}.rear drive shaft seals{twice} belt,battery,all wheel drive went out,.this has all been covered under warenty but man ,give me a break,it doesnt do me much good because its allways in the shop!,never get to ride it.
October 12th, 2008, 04:38 PM
First Name: dusty
My RZR: red 2008
i broke mine yesterday it made a loud pop then wouldn't pull then i noticed this morning oil was running out of the back of the front diff where the shaft goes inso mine does nothing at all but havn;t got to take it to the dealer yet
October 12th, 2008, 05:01 PM
the dealer replaced mine but I had to pay the labor
December 9th, 2008, 08:41 AM
The "resistor module" part number is 4010924 and the part name is "Resistor, Module". For some reason i t doesn't show as a RZR part but does across other models and is the exact same part # for other Rangers, Sportsman, etc. I had to fight with my dealer to believe me as they said they couldn't order without the part and they didn't know what a resistor module was.
Derek
December 9th, 2008, 11:08 AM
mine is one year old and is getting ready to go back to the shop for third time. I have experienced all the same front end problems. The last two times they said it was an armature and cage that broke. The only time my four wheel drive is working is when I don't use it.
December 9th, 2008, 04:12 PM
DId you check out this module? When I first checked mine it was full of mud and dirt and previous to this my "R" reverse light wouldn't show most times and then that evolved into no AWD at all. I located and took this "module" out, cleaned it and the socket and then put some dielectric grease on it and then the R pretty much showed up all the time and the AWD pretty much worked all the time. A pretty good indication this part was going bad. Another thing that can cause problems is having your battery low - it couple amplify the issues.
December 10th, 2008, 07:25 PM
I had my front pumkin go out at about 5 miles there is a plastic cage that works the 4 wheel drive. I had my dealer put a billet one in. It work great, but at 150 it's out again. This time it sounded like a bearing grinding, engages and disengages now.
