Engine rebuild - Polaris RZR Forum - RZR Forums.net
post #1 of 18 Old July 16th, 2013, 11:53 PM Thread Starter
cams-76's Avatar
Member #18556
View cams-76's Photo Gallery(0)
Engine rebuild
Redoing my 07 800. New crank bearings valves pistons valves and all. How much of a gain is it to go big bore. Thinking of 82mm/true 800. My friend is going to port the head also. Planning On bumping the compression up regardless of big bore or not but still run it on pump gas. Is the big bore worth the extra money? My cylinders are good only needing honed at this time due to glaze. Also going to out an s cam in it if I can find one.
cams-76 is offline
post #2 of 18 Old July 17th, 2013, 12:06 AM
AlbaNate's Avatar
Member #24131
View AlbaNate's Photo Gallery(0)
Re: Engine rebuild
+2mm is worth a few hp. Generally enough to require a bit more clutch weight and fuel, so with that said make sure you incorporate the cost of those additional components. We sell a +2mm big bore kit that is $750 with cylinder exchange for forum members and the compression ratio is 11.0:1.
Nate
Alba Racing
NATE@TEAMALBARACING.COM
LIKE ME AND ALBA!!!
Check us out on Yelp.
AlbaNate is offline
post #3 of 18 Old July 17th, 2013, 01:13 AM
RacerSam's Avatar
My RZR: 2009 Nuclear Orange LE, 2012 Walker Evans
Member #7858
View RacerSam's Photo Gallery(0)
Re: Engine rebuild
Nate
Alba Racing
I highly recommend this and the S aka H.O. Cam too and good exh
'16 Graphite Crystal turboXP
'14 Black Stealth 900XP
'12 Walker Evans 800
'09 Nuclear Orange 800LE SOLD
'11 rzr170 SOLD
'05 YFZ450 SOLD
RacerSam is offline
post #4 of 18 Old July 17th, 2013, 08:32 AM Thread Starter
cams-76's Avatar
Member #18556
Re: Engine rebuild
im not sure i am wanting to spend the extra cash. the exhaust that came on the rzr is a gibson. it looks like it would cost an additional $300 ish plus the cost of new exhaust.
cams-76 is offline
post #5 of 18 Old July 17th, 2013, 08:54 AM
RacerSam's Avatar
Member #7858
Re: Engine rebuild
Any good muffler with the S style dual head pipe on 09-up and all 11-up 800 is 90% as good as the aftermarket headers so I've read/heard for engine build like yours. Didnt mean you needed a new $800 exh system
'11 rzr170 SOLD
'05 YFZ450 SOLD
RacerSam is offline
post #6 of 18 Old July 17th, 2013, 08:57 AM
RacerSam's Avatar
Member #7858
Re: Engine rebuild
Also on head, a good multi angle competition valve job is worth as much as just porting head. Also look into Team Alba spring kit as sure your valve springs are worn out
'11 rzr170 SOLD
'05 YFZ450 SOLD
RacerSam is offline
post #7 of 18 Old July 17th, 2013, 10:45 AM Thread Starter
cams-76's Avatar
Member #18556
cams-76 is offline
post #8 of 18 Old July 17th, 2013, 10:59 AM
BarRZR's Avatar
My RZR: 2012 RZR 800-S L/E
Member #32278
Re: Engine rebuild
You'll probably need to change the ECU-Module to get the better timing and fuel-curves like the later model RZR's have. Also, a late-model throttle-body and MAF-sensor would be a good idea. My two-bits.........
Cheers
BarRZR is offline
post #9 of 18 Old July 17th, 2013, 11:08 AM Thread Starter
cams-76's Avatar
Member #18556
Re: Engine rebuild
This is getting expensive. I think I try for an s cam and leave it stock bore.
cams-76 is offline
post #10 of 18 Old July 17th, 2013, 11:15 AM
BarRZR's Avatar
Member #32278
Re: Engine rebuild
LOL! Ya, power and performance increases are ALWAYS measured in cubic-dollars, and there ain't no magical, cheap and easy routes to go.
Cheers
BarRZR is offline
post #11 of 18 Old July 17th, 2013, 11:26 AM Thread Starter
cams-76's Avatar
Member #18556
Re: Engine rebuild
Any tips on finding an s cam. Or maybe an aftermarket brand?
cams-76 is offline
post #12 of 18 Old July 17th, 2013, 12:15 PM
RacerSam's Avatar
Member #7858
Re: Engine rebuild
That's should work great for your application.
'11 rzr170 SOLD
'05 YFZ450 SOLD
RacerSam is offline
post #13 of 18 Old July 17th, 2013, 07:17 PM
finzup's Avatar
First Name: Steve
My RZR: '15 XP1k
Member #8105
View finzup's Photo Gallery(0)
Re: Engine rebuild
If you're sure cylinder dia. is good, go 11:1 CP pistons/rings. Cam, if you can afford it. See Zforce for porting and Serdi valve job(go +1 if you have a few $). Replace the exhaust valve guides. 'S'/ FMF header. DDP clutch kit. You'll love it. PCIII/V makes it better.
finzup is offline
post #14 of 18 Old July 18th, 2013, 11:25 PM Thread Starter
cams-76's Avatar
Member #18556
Re: Engine rebuild
Any good performance cams? Looking for an s cam but can't find one
cams-76 is offline
post #15 of 18 Old July 19th, 2013, 05:08 AM
finzup's Avatar
First Name: Steve
My RZR: '15 XP1k
Member #8105
Re: Engine rebuild
I'm not sure I'd go to the effort for an 'S' cam. Anything hotter and you may be into push rods, lifters and springs. Then you have the tuning effort to struggle through. Gets expensive. Been there, done that and had fun playing the motor.
finzup is offline
Engine rebuild ? Jcraig3 RZR XP 900 22 December 30th, 2014 05:06 PM
Engine Rebuild wvsamiam Engine and Drivetrain 13 March 21st, 2013 09:05 AM
rebuild engine speedjunky Engine and Drivetrain 5 November 13th, 2011 06:45 PM
Engine Rebuild wolfpack Engine and Drivetrain 1 February 5th, 2011 06:29 PM
engine rebuild 507rzr Engine and Drivetrain 1 April 29th, 2009 12:25 PM
