Clutching Is Key
Old February 9th, 2008, 06:05 AM
mdevans's Avatar
mdevans mdevans is offline
Clutching Is Key
Clutching Is Key
this info brought me back to speed on clutching. I hope it help's you as well. ENJOY
Re: Clutching Is Key
Old February 9th, 2008, 07:00 AM
mdevans's Avatar
I looked on epi site for a rzr clutch kit and thay show nothing. i know thay have one. i think it has a smaller speed limiter. can anyone help on info. and will it have higher top end.
Old February 9th, 2008, 07:29 AM
LTZ470 LTZ470 is offline
My RZR: Gen 1
It's under Sport Utility md...I know they make different kits for different pipes also md I.E. the LTE comes with #72 weights the DFR Exhaust comes with #66 weights, etc....
https://www.erlandsonperformance.com...utilitypolaris
Old February 9th, 2008, 07:30 AM
My RZR: Gen 1
Clutching Is Key
thanks for the info...I am trying ti learn all I can about this confusing devices
Old February 9th, 2008, 09:41 AM
powermizer powermizer is offline
My RZR: gen2
Clutching Is Key
THANK mdevans I pretty much understand how the clutch system works, but knowing who to talk to for the real answers for setting these things up is worth a million. THANKS AGAIN, John
Old February 9th, 2008, 09:49 AM
twvette's Avatar
twvette twvette is offline
First Name: Todd
The spacer it comes with is not a speed spacer ... atleast the one that comes with just their Severe Duty Belt ... its an engagement spacer ... it goes on the outside of the assembly between the clutch cover and the stock large metal washer on the large clutch bolt.
JaggedX cage,UTV Crap/XMS +6 LT kit WER shocks, Gorilla axle/CVs,Dragon Fire exhaust,Power Commander FI controller,Uni filter,KMS dyno tuned, EPI Belt/spacer,Trail Tech HIDs,Vision X stock HID upgrade,OMF Outlaw2 beadlocks Skat Trak shaved Mud Lite tires Extreme paddles 26in F 27in R for sand,ITP SS112 wheels with 26in Bighorn tires for dirt,SafeGo LED whips,Optima yellow battery,Alpine iPod Stereo,600W amp,Audio Formz 6x9 Polk Momo wakeboard tower speakers,other JaggedX billet
Old February 9th, 2008, 05:19 PM
mdevans's Avatar
I think im gonna try holz front and rear clutch spring. its only $35. if it works i will save alot of money. if it dont work. its only $35. im gonna test the cdi box first. than install springs without clutch spacer. is there a thiner spacer on the market. i would like to use one. im also gonna use the polaris heavy duty belt. im thinking i might sell the cdi box. i hope to get $399. if it pulls the wheel's off the ground i will keep it. but i dont think the box is doing me any good for the way i have my rzr set up. i think fmf slip on exhaust and slight clutch mod will give me a better hole shot. than the cdi box will. if i dont keep the box who wants it for $399 it cost $300 for a stock cdi and $399 for programing.
Old February 12th, 2008, 07:08 AM
chp-sk8 chp-sk8 is offline
My RZR: green RZR
I was looking at ordering those 2 springs also...have you installed them mdevens? Is it worth the $$ ?
Old February 12th, 2008, 09:55 PM
douglas barber douglas barber is offline
i got the two springs from holz,think there great,gives you approx 300-400 rpm before they engage then they down shift quicker,made a big difference,no top end but lets you accelerate quicker and is great for tight courses when your in and out of the gas alot
  #10 (permalink)
Old March 26th, 2008, 09:03 PM
m741329 m741329 is offline
Does changing the springs take away from top speed? I am looking on getting an aggresive clutch set up. Which will give me the best all around performance.(acceleration, and top end) Any advice I will be running LTE's dual exhaust with LTE's EFI Controller, and stock tires. If I hit the rev limiter I will get the ecu reprogramed then. Thanks.
