Re: Trail Armor bumper & A-Arm guards |
June 18th, 2008, 12:41 PM
First Name: Blake
Originally Posted by HOLZTECH
That's not our bumper. This is
Its all good. He was talking about the hood vent.
08' RZR
2" RubberDown Lift
27" XTR on 14" Crushers
Bimini Top
1/2 Windshield
Trail Armor Frt Bumper
June 18th, 2008, 12:55 PM
holzracingproducts*****
woops...
Yes, the vent comes with a template and rivets (most people replace them with screws)
no worries, just misunderstood what he was asking.
June 18th, 2008, 01:02 PM
My RZR: Green '08
I'm not sure what that has to do with my queston regarding cutting the hood but that's ok
June 18th, 2008, 07:54 PM
I also have the trail armor bumper. Looks nice and real solid but a bitch to install.
You need to remove the roller fairlead and fairlead mounting bracket. The upper mounting bracket on the bumper does not fit between the frame tubes flush against the plate that the fairlead mounting bracket bolts to. Therefore I had to use smaller diameter and longer bolts than those supplied with the bumper. The lower mounting bracket mounts to the skid plate under the front diff. Like me, if you don't want the bolt thread protruding down and exposed under the skid plate and instead run the bolt up from the underside you will have a hell of a time squeezing a wrench in between the diff and skid plate to hold the nut. It took me longer to install this bumper than my wheels, rear bumper, windshield, gas can, nerf bars and roof combined.
That said. I am happy with the bumper.
June 23rd, 2008, 11:04 AM
So...any update in regards to if this bumper is a "shit shoveler"?
Need a bumper...like the price and looks solid.
Mounting issues....is the UTV Crap or Holtz mounted much differently?
Thanks!
June 23rd, 2008, 12:17 PM
First Name: Sherman
My RZR: Blue Silver Black one
utv crap bumper mount to the bottom and to the winch mount solid like like a rock. I got one I tring to sell if interested pm me an offer
June 23rd, 2008, 01:26 PM
PM sent
August 23rd, 2008, 07:21 AM
First Name: todd
My RZR: 08 800 green
cool I just ordered a trail armor.
August 23rd, 2008, 08:54 AM
First Name: Scott
My RZR: 09 RZR
Originally Posted by zrated
If I do end up running into something the mounting points won't go through the radiator.
I hear this concern a lot and it is a valid point. However, I have yet to read a post on this or other forums where someone has had this happen to them.
I'm also taking into account that we are talking about a mild to moderate impact with something and not a front end collision with an immovable object or another vehicle at full speed. Frame mounted or not, in a serious crash the entire vehicle and it's occupants will probably suffer some damage regardless of how the bumper is mounted.
I'm just curious if the concern over the factory mount points damaging the radiator is really a valid concern. I'm guessing that if it happened all the time there would be more threads complaining about it.
August 23rd, 2008, 10:07 AM
First Name: Kevin
My RZR: Red
It is a valid concern, it does not take much of a hit to damage the radiator using the Polaris "brush guard" not bumper.
August 23rd, 2008, 10:37 AM
First Name: Scott
My RZR: 09 RZR
Are you speaking from first hand experience or just repeating what others have voiced in the forums? Again, I think it is a valid concern but I have not read anything to indicate that this is actually happening on a regular basis.
August 23rd, 2008, 01:11 PM
Originally Posted by Johnny
the problem with that bumper befor you all run out and buy one is it sticks out so far on the bottom when in the dunes and jumping in the dirt ect ect it hits everything and scoops up piles of shit and puts it in your face
August 26th, 2008, 08:54 PM
You don't have to look very hard, here is one on this forum.
http://www.rzrforums.net/general-rzr...yone-else.html
August 26th, 2008, 09:13 PM
First Name: Scott
My RZR: 09 RZR
Originally Posted by RedMan
From looking at the photo in that thread and from the 2nd person who posted about fin damage, it doesn't appear that the bumper mounts themselves caused the radiator fins to crinkle due to their failing. In fact, from the picture it looks like his bottoming out might have been the cause of the fins crinkling. In both cases, the only thing that happened was the fins were crinkled, the radiator was undamaged and was still functional.
What I am waiting to hear is if this guy who recently flipped his RZR over had any damage. The pictures clearly show his RZR on its front bumper in a vertical position, impacting the ground. If his radiator wasn't damaged by the bumper mounts then I'd venture to say it's not as big of a concern as some make it out to be. In this case I would honestly expect that there might be damage.The whole thread on this can be found HERE.
August 26th, 2008, 09:23 PM
First Name: Phil
My RZR: 2008 Green GEN3 RZR
my fins are damaged on mine on the driver side. it was caused by the bumper being pushed upwards from hitting a rock. it bent the front of the skid plate on the bumper up which shifted the whole bumper upwards. radiator is fine other than the crushed row of fins on one side. no leaks so i'm not worried much about it, it can't be pushed up any farther,
2008 Green RZR- Front and rear deluxe bumpers,rock sliders,polaris 3500 winch with wireless remote,RCI 4 point harnesses,ITP wheels with 27 inch mudlite xtr's,Lone star gas pedal with KMS heavy duty spring,KMS intake setup with custom snorkle,Rotopax fuel cans,Roktek 3inch Lift.
