Originally Posted by L86fae
I went with a wide off set ITP C7 rim and Rhino to RZR adapters. BIG mistake. The wide offset with the 1" spacers made the suspension super soft. I was hitting hard on even small bumps. I set the stock shocks to the stiff setting and it did not help.
I have a similar set up and also hit the skid alot, but would much rather be hitting the belly than the side from being too narrow. Clearance can be fixed with good lift kit, bigger tires, or long travel.
