Originally Posted by RZRider
O.K. for me it's important to switch back to 50 inch width so I can ride a few select trails so I just remove the off-set tire/rim assembly I have off my Sportsman and install the stockers.
I have some AFCO's that I absolutely love but I'm curious as to what I give up by not having the Long Travel other than some stability and more clearance when I'm not on 50 inch trails?
I do abuse my Holz skid plates because of clearance issues but I sure would hate to give up riding the narrow trails.
If you choose to give up the 50" trails and go wider, use the LSR 4" MTS or any other kit that utilizes the stock length shocks and you can use your AFCO's as is. Maybe a spring change depending on the ride height you desire.
