Thread: Wheel Alignment
View Single Post
Old January 8th, 2008, 08:45 PM
RZRider's Avatar
RZRider RZRider is offline
First Name: Al
My RZR: 08 Red
Re: Wheel Alignment
Originally Posted by odtodd1az View Post
rzrider, the tires have a seam in the middle, why paint em. the other thing is you need the suspension at ride height for proper adjustment. the rope thing also gives you a chance to see the rear toe in. This is what helps push the car straight. If we run a race that we need to use 4whl dr. then we go zero to 1/16t toed out to make the front axle work correctly
No seam if the tires are worn.
If I wasn't clear let me say...After you mark the tires you lower the RZR back on the ground push on the suspension and then rock it back and forth so the suspension "settles".
At my dealership we use the rope technique, I was just throwing out an option I've seen used.
My RZR Project
Keep It Wet and Dirty!
