View Single Post
Old September 30th, 2008, 05:31 AM
normsfirebird's Avatar
normsfirebird normsfirebird is offline
2009 Razr S
My RZR: 209 Razr S Model
2009 Razr S Ground Clearance Issue
I have a 2009 Razr S I have had it for about 3 weeks now. I adjusted the pre load to about 3/4 the way down to give myself 17 inches of ground clearance the first week I had it. After 2 weeks it had setteled to about 13 and a half inches of ground clearance. I put 28 inch tires on the stock rims and it took it back up to about 15 and 3/4 inches of ground clearance. I measured it today and its at 13 inches exactly. I am thinking either I have 4 bad fox podium shocks and or 4 very weak springs or the shocks/springs arent designed to be exteded all the way up and left in that position, I have reviewed the DVD that comes with the machine and it says to raise them with heavy loads then readjust them to stock afterwards. I think leaving them adjusted up weakens the springs and causes the UTV to settle. Im looking into a lift but I am also very concerned with travel in holes and jumps causing axles to pull out of the splines and or binding and comming apart. Anyone else adjust thiers up and it settle? Other Opinions please?
2009 Polaris Razr S Model
Remove advertisements
Sponsored links
