View Single Post
Old September 28th, 2008, 08:48 PM
guy48065's Avatar
guy48065 guy48065 is offline
Re: I need advice on installing harnesses on my rzr
Originally Posted by Kim View Post
We removed the factory seat belts and are having a little difficulty installing harnesses on our rzr. Where or to what do we bolt the lap belt to on the right (passender side) and left (driver's side)? Do we drill a hole in whatever metal is in the area where it should go and bolt it in? Where is the best place to put those two bolts?
Just use the same hole the original retractors were mounted to. You'll need to take out a few plastic rivets in order to pull the plastic away enough to reach in & hold a nut in place.
Now a 2-Rzr household.
http://tinyurl.com/8ltm8
