Re: PIAA 525 Lamps
I installed a set of the Hella black magic's on mine. I had a set laying around left over from a truck build. Anyways I only used about half of the wiring harness pieces as some were not really needed in this application. So you should be fine just wire them direct like any other lights. Just put a fuse on the pos lead. I'm sure you knew that though.
Four Time APBA National Champion
2007 IJSBA World Champion
Over 100 career podium finishes.
Where's your JUDGE.........
