in
this forum
in
the entire site
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Marketplace
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Light Mode
menu
Log in
Sign up
Home
Forums
Technical
RZR 1000 Engine
Follow Forum
Create Thread
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
1
1 of 13
Go to page
Go
13
C
Used bearings?
Codymxer
Mar 9, 2024
4
584
4d ago
by
markgam
The infamous flywheel bolt issue!
Jhill18
Mar 7, 2024
Poll
7
405
Mar 7, 2024
by
SNWMBL
R
2017 XP1000 Misfire Help
Rockcrawlr
Nov 19, 2023
7
3K
Dec 31, 2023
by
Rockcrawlr
S
2024 XP 1000 Ultimate With Clucking Noise At Take Off
Sweetlou
Dec 29, 2023
6
2K
Dec 29, 2023
by
Crash City SxS
L
Peak horsepower rpm:s?
Lemon Welder
Dec 21, 2021
1
3K
Dec 27, 2023
by
info_4929
P
2015 RZR Xp100 4 error code meaning for these?
Purehobby
Nov 9, 2020
1
3K
Dec 5, 2023
by
axv0223
Full throttle cutting out
motoracer057
Jul 11, 2015
2
47
76K
Nov 20, 2023
by
elizondo.erick
Cam timing and alignment, does this look ok ?
oilcan1001
Oct 8, 2020
18
19K
Nov 20, 2023
by
SNWMBL
Throttle body issues
Jobu
Sep 18, 2023
13
4K
Nov 14, 2023
by
CrazyElecE
Tmap pigtail wiring
Badcat64
Apr 16, 2021
3
4K
Nov 12, 2023
by
jbh6999
Oil pump failure
James Coen
Nov 6, 2023
0
1K
Nov 6, 2023
by
James Coen
Engine malfunction
sorensen.michael17
Oct 15, 2023
2
1K
Oct 16, 2023
by
Cyberdiesel
C
Rough idle code 520344
Connman
Jan 12, 2016
17
59K
Oct 6, 2023
by
joelh3942
A
rzr xp1k trouble code 636 2
anthkrueger1
Feb 7, 2018
4
7K
Sep 2, 2023
by
Snap3
Electronic throttle troubleshooting
Riddler6.7
May 7, 2017
17
31K
Aug 26, 2023
by
a2r4life
Engine - buy used or new
Prcsc
Jul 31, 2023
9
3K
Aug 21, 2023
by
Trailwolverine
D
2019 xp4 shut down mid ride. No fault codes
dom08
Jul 25, 2023
2
1K
Jul 26, 2023
by
dom08
D
Rzr 1000 idle problems
Dcampbell1172
Jun 14, 2023
2
1K
Jun 14, 2023
by
Dcampbell1172
Stroker XP1K
Friesen81
Jan 13, 2023
14
4K
Jun 8, 2023
by
Tomahawk
Engine build in progress
Donkayrzr
Jun 6, 2023
1
1K
Jun 6, 2023
by
huhner5
02 Sensor code thrown in 2016 RZR 1000S
Bilzer
Jun 1, 2023
4
2K
Jun 2, 2023
by
Jobu
A
Belt Q: Proper way to descent steep trail?
Al Simons
May 26, 2020
8
6K
Jun 2, 2023
by
DesertDuo
Con rod selection help
Donkayrzr
May 25, 2023
3
1K
May 26, 2023
by
Donkayrzr
A
Recommended shop to do XP1k performance motor work
areax
May 20, 2023
2
1K
May 21, 2023
by
areax
J
Razor 1000 timing and shimming
Jlenning2958
May 10, 2023
9
1K
May 11, 2023
by
Jlenning2958
C
Balance shaft
Cmd123
May 7, 2023
1
1K
May 8, 2023
by
Gotwheels
Code issues
boerzr
May 25, 2017
8
14K
May 2, 2023
by
wilfongcameron
HELP!! 2014 rzr xp1000 stutter at between 6-7k rpm
Tannerp313
Apr 15, 2023
1
1K
Apr 16, 2023
by
KC Desert
H
tuner
hillinit1
Apr 14, 2023
5
1K
Apr 14, 2023
by
Turbo_ryan
Rzr 1000 xp non turbo 201 engine problem
Anthony_06
Mar 29, 2023
5
2K
Mar 29, 2023
by
Medi0gre
B
clutch cover
Batty2021
Mar 25, 2023
4
1K
Mar 27, 2023
by
CrazyElecE
RZR 1000 camshafts on General 1000, Will they fit?
zeyad
Feb 12, 2023
0
1K
Feb 12, 2023
by
zeyad
PLEASE HELP - 14 XP1K CODES - 190, 84, 520226 IVE TRIED EVERYTHING!!!! SCORE SPEC BUILD
1154RianEllis
Apr 7, 2021
7
8K
Jan 24, 2023
by
DgAus
XP 1000 Engine Rebuild Kits
SlickND
Jan 7, 2023
7
4K
Jan 16, 2023
by
CrazyElecE
Motor Rebuild - Big Bore or stock?
Mlocks13
Jan 4, 2023
9
2K
Jan 7, 2023
by
Glock10mm
1
1 of 13
Go to page
Go
13
RZR 1000 Engine
4.1K
posts
2.9M
views
All Engine and Drivetrain discussions on the all new Polaris RZR 1000.
Show Less
Join Community
Grow Your Business
Forum Staff
View All
185EZ
RZR_Joe
Denver
Top Contributors this Month
View All
Jhill18
K&M
S
SNWMBL
Recommended Communities
AVS Forum
1M+ members
Deals Forum
1K+ members
The Polaris XPEDITION
100+ members
Home
Forums
Technical
