View Single Post
Re: clicking in front end when turning, coming from the wheels
  #40 (permalink)
Old July 9th, 2008, 02:42 PM
mushman254 mushman254 is offline
Originally Posted by snack747 View Post
mines got bout 40 hours and around 700 miles and it just started on the front passenger corner is the only one that does it. after looking at it we came to the conclusion that it was the brakes cauise they were rubbing a little, anyhow rzrz are prone to braking hubs which can cause the cvs to go out if its not fixed. it will make that clicking noise and the way to check if the hubs are broke is jack it up and grab the tire by the top and bottom and see if it rocks and if it does you just solved your problem. hope i could be a help
mines clicking too, 300 miles, jacked it up and no wiggle in the front tires but the shafts coming out of the front diff seem to be loose
