Re: HELP!! Confused 12 inch rims or 14 inch
So of course your not running 14'''s. They only just came out with a 25'' for 14'' wheel and it's the terra crosses.
Do you hit the limiter often ? Are you running ECU upgrade?
I think that 12'' wheel is good for 25'' tire and 14'' wheel is good for 26'' tire. It's close to same tire to wheel ratio.
