View Single Post
RickyRazr's Cage Build
Old June 20th, 2008, 08:27 AM
RickyRazr's Avatar
RickyRazr RickyRazr is offline
Talking bout' Yankee Rose
First Name: Rick James Bitch!
My RZR: Green 3rd Gen
Hello All,
Since I have the tools and shady tree skills to build a cage, I decided to build one myself. I ended up being able to find some 1 3/4" .095 wall DOM tubing. The whole cage will be built from this material.
The stock mounting pads for the stock roll cage are pathetic at best. I am beefing both front and rear up with some 3/16" steel plate. The rears will be held in place with four grade 8 bolts per corner. The fronts will be welded down.
Here is a shot of the cardboard template that I made which will be transferred to the sheet to be cut out with the plasma cutter.
The outcome. Two parts clamped together and ground evenly to produce identical parts.
