View Single Post
Re: clicking in front end when turning, coming from the wheels
Old June 10th, 2008, 11:11 PM
Makin' Trax's Avatar
Makin' Trax Makin' Trax is offline
I have been installing a LT kit from Mafia on the UTV Offroad Magazine RZR. What I found is that all the pivot points holes are so oversized that the bolts have almost an 1/8" slop. You can loosen the a-arms and the hub bolts in the rear and change the camber from negative to positive. We installed weld washers to remove to play. Check these points and make sure everything is tight. Also the bolt that holds the ball joint to the front hub was worn and allowed movement.
