View Single Post
Re: Boost/Vac., Pyrometer, Oil pressure, & Wideband o/2 Gauges
Old May 27th, 2008, 01:56 PM
THNKTWCE's Avatar
THNKTWCE THNKTWCE is offline
When you go wide open throttle the a/f should get to a number IE: 11.5 and should stay around that normal. If you are seeing numbers like 11.1 to 12.1 under WOT, then I would want to dyno it, and straighten out the fuel curve.
Just Muddin!
