View Single Post
Re: air cleaner problem
  #43 (permalink)
Old May 15th, 2008, 11:01 PM
LTZ470 LTZ470 is offline
My RZR: Gen 1
Originally Posted by shanep View Post
Hope you know that by changing the filter by its self won't fix this problem. I have had the hose between the air box and the intake come off twice at the intake side. This allows dirt and sand to be sucked directly into the motor. This is a devastating problem and should be fixed before you go out riding. Especially if you are out of warranty. I was under warranty and they have given me a new top end. however, the original problem has not been fixed
or attempted to be addressed. Go Figure.
After careful research I installed the K&N Apollo. The Throttle Body Boot End was wrapped with Electrical Rubberized Tape that you stretch to initialize the stickiness or adhesion then the boot was put onto this and tightened, the rubberized tape sticks to the rubber boot also. Same was done on the K&N Filter inlet to Throttle Body Rubber Boot. It's a little difficult to get off because it does stick to the surfaces but you don't have to worry about it coming/slipping off under load...the Apollo System works great and I had Outerwears make me a prefilter for it so it is even better now...
