i recently found out the hardway how weak some of the Polaris welds are. while racing at a track my upper front a-arm rear tab pulled off the frame. i was comming fast into a right turn and the right side of the car came off the ground, i quickly turnned into it and the left front upper arm ripped off the frame. and i landed on my drivers side while the other racers went on by. i was helpless and felt like a ID10T for going so fast into the turn.
upon inspection i found out the upper rear arm tab pulled off the frame and the car drove over the wheel.
when i got home a tore apart the car to fix this issue i found even more damage. a broken hub,
mushroomed spindle,
bent tierod end,
plus a bent bolt and tore boot on balljoint.
now for the fix
and beefing up.
this is a complete Polaris RZR weld on gusset kit from LONESTAR that corrects all of the weak points of the RZR. now we can go out and beat on the RZR without worry. it a complete weld on kit and takes some time to install but will be worth every minute it takes to remove the paint off the frame.
