View Single Post
Old March 28th, 2008, 12:26 AM
BIG ISLAND KART SHOP's Avatar
First Name: JASON
Re: My 2007 Tundra 5.7 w/9'' lift 35''s on 22''s
Tundra is tighter in the wheel well area than dodge. With 9'' wide wheels I could have run 37'' tires but I like the width with the 12'' wide wheels. I have a 6'' susp. & 3'' body lift. If I had a true 9'' susp. lift, I probably could have fit a little taller tires on these same rims.
