View Single Post
Old March 26th, 2008, 10:58 PM
BIG ISLAND KART SHOP's Avatar
First Name: JASON
2007/2005 YFZ 450 Full Race $15k+ to build
NOLEEN CUSTOM SHOCKS, FRONT & REAR, LONESTAR LONG TRAVEL A-ARMS, HOUSER STEERING STEM, FLEX BARS, DYNATEK IGNITION, RATH, PRO PEG NERFS BUMPER & GRAB BAR, GIBSON SUBFRAME, LONESTAR BATTERY BOX, HOUSER SWING ARM, SIDEWINDER CHAIN & SPROCKETS, DURABLUE AXLE X-33 WITH PIN DRIVE, HYPER CARBON FIBER BEEDLOCK WHEELS, CT PIPE, SPARKS PISTON, FULL PORT POLISH W/VALVES, HOT CAMS & ROD, HINSON COMPLETE CLUTCH, R&D CARB MOD AND BORED CARB, ATHENA BIG BORE 480CC PUMP GAS, 2007 MOTOR UPGRADE BEFORE MOTOR WORK WAS DONE, AND OTHER SMALL THINGS I FORGOT TO MENTION. ONLY 10 HOURS SINCE BUILT, RUNS/DRIVES PERFECT.
Call me if interested.
$7500
(808)896-1499
Remove advertisements
Sponsored links
