View Single Post
Old March 26th, 2008, 02:25 PM
Baditude's Avatar
Baditude Baditude is offline
Need tire / rim advice
Ok I have read every forum thread I can on tires / rims but have a few questions.
First, I have the 2" lift kit and I don't want the new tires / rims to rub
I understand that a 12" rim has more side wall then a 14".
12" better for rock crawling
14" better corner at speeds can also get bead lock
I ride in IN, KY (Evarts), soon WVA, Tenn and I like mud / trail riding not so much rock crawling off camber
From what I have read Bighorns are are the all terrain tire of choice
I had 25" Mudlites on my Prarie but with the SRA I had about 8" clearance and got hung up alot -so mudding kinda sucked
I also read you want -.43 offset, wheel spacers or bolt conversion
(this is a bit fuzzy)
So what is better for me? Trying to stay under 55 inches and avoid spacers etc.. if I can help it.
26 or 27" tires? (I heard 28" will rub and rob to much power)
SS112 rims look great but $140 for conversion = forget it
SS108 is what we like 2nd best
If I see a mud puddle, I will go through it but also do lots of normal trail riding.
Thank you all suggestions are welcome
Remove advertisements
Sponsored links
